Safety cover not draining water
Judge
22
Hey everyone,
Has anyone had the problem with water pooling on top of their safety cover? If so what did you do to fix it?
Thanks
1Sammy
In The Industry
Jul 20, 2017
403
Windsor, Ontario. Canada
There you go, it is working and doing what it should. Now your pool water is protected from rotting leaves if you have them and dirty snow for those that have it. Perfect set up. Now just to do as "proavia" suggest.
bmoreswim
Platinum Supporter
6,548
Central MD
Hayward Aqua Rite (T-15)
I think the replies above would be for a solid cover. Taking a different look at this, is this a mesh cover? If so, it's not tight enough and should not be touching the water. It appears to not be an issue of it not draining, but that it's touching the water which makes draining impossible.
Homebrewale
354
Apex, NC
Hard to see the springs. The instructions on my Loop-Loc say the springs should be compressed 60%. Also can't see any springs along the edge of the stone wall so I don't see how the cover can be tightened.
