Rust along entire inner and outer bottom and wall bumping out
KristineC
7
Wappingers Falls NY
Hayward Aqua Rite (T-9)
Hi everyone. I’ve followed along for 5 years since buying a home with a 24’ round, salt water, above ground pool. I appreciate all of the help!
We bought a replacement liner this year because we’ve had leaks the past two and could not repair the last one. When we removed the old liner, we found the walls to have rust all long the bottom on the inside and outside. It also looks like the bottom above where it connects to the rails is bumping out. I’ve included photos in case that helps.
Does anyone have experience with this and have any advice on repair or replacement. The rust does not seem to have gone through completely but it is along the entire wall so it’s possible we missed a hole somewhere. The bump out is what seems more concerning.
My husband wants to try to repair and go the year. I’m worried about the pool collapsing and flooding the house. I’ll take any advice!
ajw22
25,665
Northern NJ
Pentair Intellichlor IC-60
Welcome to TFP.
I think your pool is on borrowed time and it should be taken down before someone gets hurt if you have a sudden failure.
Let's see what @Casey and @zea3 say.
zea3
13,526
Houston, Texas
Hi welcome to TFP! That bump out is where the wall is starting to buckle under its own weight. I don't think it is going to be repairable, since the rust probably will go all the way through when you try to clean it off. The rust is where the wall inserts in the bottom track. The top and bottom tracks are what holds the pool in a circular shape. Physics tells us that one of the properties of water is that it will always seek level. It will spread out as much as it can, and it pushes out equally in all directions. When you have a weak spot in the wall the water is able to push harder in that area and the wall will fail. How long it will last before it fails is anyone's guess.
I would take it down and invest in a new pool with resin walls. I would not attempt to patch the wall since you say the rust goes all the way around. If you really want to save the pool, then the safest thing you can do is measure up about 6" or until you hit good metal, and cut off the bottom of the pool wall. It will make the pool shallower, but I think that is the only way to save it.
If you want to see what rust can do a pool, clink the link to my sad story. RIP Rusty Vogue Pool
kellyfair
4,617
Tampa, FL
Intex Krystal Clear
Pool isn’t safe. When it collapses, it will at best make a big mess, and at worst, hurt someone.
Reactions: KristineC
KristineC
7
Wappingers Falls NY
I am sorry for your sad story but thank you so much for sharing it. That is one of my biggest pool fears!
KristineC
7
Wappingers Falls NY
Welcome to TFP.
Thank you for taking the time to read and reply. We’ve ordered a replacement!
Casey
11,935
SW PA
Fiberglass
Jandy Aquapure 1400
I'm glad you purchased a new pool. When it comes to safety, we must go above and beyond protecting everyone in and around our pools... including neighbors.
KristineC
7
Wappingers Falls NY
Update thread
Here’s a brief photo run through of our pool story. We are very happy but do have some questions if anyone can share in the update thread above. Thanks all!
Last summer in our old pool. We thought we had a lot more life in our pool and it was so good to us for 5 years after buying our home with the pool there.
Old pool liner removal after we lost half of the water and thought we just needed a new liner.
Old pool inner wall damage discovery.
We had no idea how bad it was. Yikes.
Goodbye old friend. Hello new friend! Our new build!
24Aurora Saltwater Resin with an overlap expandable liner.
Stretching the liner in slowly
We have a pool!
kellyfair
4,617
Tampa, FL
Intex Krystal Clear
My pool has a new big sister! Congrats!
