Running a robot cleaner while pump is running?
Fronzizzle
55
Augusta Township, Michigan
Hello all,
I have an above ground pool and I just purchased a robotic vacuum (Warrior SE). I just put it in the pool for the first time and have a quick question: is it better to run the cleaner when the pump is on, off or no difference? I've been watching it for about 30 minutes, it likes to climb the wall in some places but not others; just wondering what will happen if it climbs to the skimmer or return jet while it's running.
mknauss
29,738
Laughlin, NV
In my in-ground pool the robot runs right over the returns and skimmer with no issue. Pump running. Though it is a VS pump at a low rate.
I do not think the wall climbing robots are really designed for an above ground. The transition from floor to wall is pretty abrupt.
Take care.
Reactions: WilliamD
Fronzizzle
55
Correct on both fronts - it is a Warrior SE, and it was designed for in-ground pools. However, I spoke to the fine people at Marina Pool & Spa (this is where I purchased it from) and they assured me that it's fine to use for an above-ground - it won't cause damage or anything. The only potential issue - the one I'm seeing - is that due to the steep angle of the walls, it may not climb the wall.
To be clear, I'm 100% fine with it not climbing the walls, or only doing it in certain areas. My concern was that IF the skimmer and return were running and IF the robot happened to climb the wall there, would something bad happen - like would the suction of the skimmer make it so the robot couldn't move, or would the return "blast" it off the wall or something.
