RS-485 Connector - Help me identify source this
mzuri
29
GA
Hi
Help me source this connector, please. Its a 4 terminal removable block on Hayward VSP and Jandy. I have googled high and dry without finding it and am loathe to wire up using maybe crimp connectors with the high voltage around.
Thanks
BowserB
162
Katy, Texas
Have you tried Hayward? Jandy? FWIW, my Pentair Intelliconnect box uses an RS485 cable to connect the Pentair Intelliflow VSF pump. It only uses the green and yellow wires. I know...not much help. However that does suggest that there may be multiple uses of RS485 serial connections and the equipment manufacturer is the best bet. I've gotten a lot of information from Pentair tech support--and that's especially good, since my pool builder didn't even know the Intelliflow pump could be connected to the Intelliconnect box, even though the RS485 cable was shipped with the pump.
ogdento
378
Chico, CA
Hey guys,
it's a Riacon 4 PIN, Metz Connect, 31007104. How many do you need?
-Tom
p.s. The phoenix connectors are used on screenlogic and intellitouch indoor controllers (maybe others)
mzuri
29
GA
Hey guys,
-Tom
Thanks Tom!
I need 2. The magic of mind melding!
