- May 22, 2020
- 34
- Plaster
- Saline Generating Systems Breeze 760
I'm in the market for a robotic pool cleaner that will clean as much of my pool as possible. Unfortunately my pool has a relatively large Baja / Sun shelf that the prior owner put in and it regularly gets dirt / debris that even when brushing off some pieces manage to float back and land on the sun shelf. I end up having to use a pool vac on a pole to clean the sun shelf effectively currently.
I would like to find a robotic pool cleaner that is smart enough to handle cleaning my sun shelf if one (hopefully) exists now. I read posts from a couple of years ago that state they didn't.
Also, if I drop my robotic pool cleaner into my hot tub would that mess up any "learning" that it does?
Thanks
Thanks
