Robot Use In Winter?
HeyEng
77
Oklahoma City, OK
#1
We are about two weeks out from closing on our next home that has the pool described in my sig line. I have been busy, busy, busy reading all about pool maintenance, etc. in preparation of being a pool owner. After some contemplation, I think we will be getting a robot cleaner. Anyway, we will not be closing the pool, so was curious if anyone runs their robots when the season is over. I imagine there is degraded performance temperature and a do not use temperature but was curious as to the opinion of the forum users. There will be some debris from some trees, but I imagine once the leaves have fallen, that will be reduced. What are you thoughts/opinions?
Jimrahbe
10,560
Bedford, TX
#2
he,
Not sure what my manual says, but I have three robots that I have been using all year long. Two of them are really old Dolphins that I bought used about 6 years ago and the one at my house is a newer style that is over 4 years old. I can't tell any difference in performance winter or summer.
Geebot
694
#3
he,
Well, it's 51 degrees right now in Bedford and 26 degrees in Oklahoma City, so applying a Bedford standard to Oklahoma may not be the best advice.
bongardjm
37
Canton MI
#5
I use mine a couple times over the winter to clean up the worms/bugs/occasional leaf that finds it way under the winter cover. The cold water doesn't seem to bother it. I normally run a cycle or two and then remove immediately, rinse off and put back in storage. Also apply an chlorine/muratic acid if needed to balance out as the robot can circulate. I have not yet done the whole "break the ice" and slide the robot in. That might a little extreme! Just try and clean as good I can before deep winter sets in.
Geebot
694
#6
For the S300, at least, the manual recommends use in water between 43 and 93 degrees (and storage in ambient temperature no lower than 41 degrees). I can see that using it in cold temps might lend itself to removing it in potentially freezing temps with some water inside - which could then freeze, if not promptly placed in a warm location.
borjis
2,643
Pacific NW
#7
My Dolphin E10 manual says not to use it if the water is below 40 degrees.
Water is currently around 45 so I used it last weekend.
My understanding of what happens below 40 is that the lubrication in the moving
parts has a difficulty doing it's job well at that temp and thus pre-mature wear
can occur.
I don't use mine if the water is below 40 F
HeyEng
77
Oklahoma City, OK
#8
All sounds good, thanks so much. We close on the house tomorrow and are supposed to take possession on Friday...and of course there is a good chance for an ice/winter storm Friday and Saturday. Needless to say, I am somewhat concerned what may happen with the pool while we don't have possession, especially since the seller will most likely not be able to get out by Friday. I really wish we had the seller winterize the pool as a condition of the sale. Oh well, not too much we can do now!
