Robot starting to get stuck on drain covers - Maytronics no help
Cody
222
Prosper, TX
I have the Dolphin 300i, and bought it about 1.5 years ago. It's just becoming an issue with it getting stuck on drain covers (i have 4 covers). I called Maytronics and was told they don't have any adapters for and of the robots like mine. They told me to buy drain clips, but when I visited the web site for the clips, they say specifically that robots have mixed results.
Any tips or advice?
JoyfulNoise
Platinum Supporter
May 23, 2015
17,622
Pentair Intellichlor IC-40
It gets worse with age as the treads wear down. My S300i is going on 4 seasons old and it definitely sits on the drain covers a lot longer than it did in previous years. My treads are very worn down so I will be replacing them at the end of the season. I expect that will restore some of the original ability to sail over the drain. Dolphin should really redesign the bottom suction port with a more flexible rubber lip as opposed to the hard molded plastic, it would likely help solve the high-centering problem.
Cody
222
Prosper, TX
Yes, pretty disappointing that Maytronics rep basically said "can't help you" except to recommend a clip on the drain covers...the problem with those is that my pool is deepest in the center, and only about 5 feet deep, so we walk over the drains all the time...seems that would be really annoying to have the clips.
Ted Y
Active member
May 8, 2012
39
Phoenix, AZ
Cody, are you talking about the ramped drain covers? I just ordered one. I have the Pentair Warrior that gets stuck. We'll see how it works.
panic_button
207
Panhandle Florida
I have the same issue with a M600. Maytronics was no help with any support or ideas, but I did find adding a 4" piece of noodle to the handle helps.
rcerf
62
Bastrop , Tx
Hayward Aqua Rite (T-9)
Check out post number 10. I’m going to give the Teflon idea a shot.
