When they create the “concrete pan” to hold the boulders it should be tied into the pools main structure. It needs to be very thick, 8" minimum I would say as natural stone is very dense and heavy. The ground around it also needs to be very well compacted and not subject to shifting, you might ask that the PE that does the engineering drawings has input on that part of the design to ensure the soil and structure holding the boulders doesn't move. they might want to add footers or piers to the pan. All of this is on the PB to do correctly, the waterfall sub has nothing to do with the creation of the pool structure.
Once the pan is in place and cured, it needs to be sealed. My waterfall guys used Laticrete HydroBan concrete sealer to seal the pan before the boulders were placed. They also need to use a waterproof mortar mix for stones. This should all be worked out in a meeting with the waterfall subcontractor PRIOR to the start of any work or, better, before a contract is signed.
One design suggestion - I would highly recommend, from personal experience, that you do not allow them to create levels to waterfall where the water pools in a small basin and then overflows to the next level. It should be all flat surfaces that drain quickly. You will absolutely not want to run the waterfall all the time and small basin pools create the headache of having to run the waterfall many times per day or else the water in the basin loses sanitizer and goes green. I have it on my pool to-do list to fill in all my basins (I have four) with hydraulic cement because I can't stand the fact that they occasionally go green from lack of sanitizer. It's a nuisance and creates more work and pump run time on your pool.
As others have stated, the waterfall should have it's on separate plumbing and pump. You should also use a waterfall pump or, if those are not available, a variable speed pump, on the waterfall plumbing. Mine was built with a single-speed WhisperFlo 1.5HP pump and it's a total energy hog (which is why I hate running it). Waterfall pumps are designed for waterfalls - high volume flow rates at low pressure. Pool pumps are NOT waterfall pumps so don't allow them to put a pool pump on the waterfall plumbing.
