Can someone please look at the diagram of my pool to provide suggestions on the proper direction I should have the return jet eyeballs pointed for the best skimming circulation? I have 3 return jets with them pointed up slightly making small ripples on the surface and the middle return is twice as powerful as the other two. The diagram shows the direction I have the returns pointed currently and the location of the skimmer. I have many trees around my yard so there is always leaves and debris landing in the pool and I seem to have the most accumulation of debris in the deep end opposite that return. I made the diagram show the usual place the Polaris hose sits after the timer has turned off and it seems like the hose blocks some of the water flow to the skimmer but even while the Polaris is running, the debris hangout doesn't really change. I run my single speed pump about 10-12 hours per day with the valve at 75% skimmer and 25% drain suction and the Polaris 4-5 hours per day so I know I am running them both enough to clean.
Thanks in advance for the recommendations.
