Retaining wall and U braces
recklesscowboy
2
Nor California
Have a used 12x24x52" intex pool want to place one long side next to rock retaining wall with plywood or rubber sheets between rock wall and liner can I eliminate the u braces save space or just make them vertical between wall and pool
ajw22
18,959
Northern NJ
Welcome to TFP.
If you eliminate the U braces that pipe will not have sufficient support and probably bend.
If you make the U braces vertical they will be too long to make that pipe level with the others.
This the pool we are discussing?
recklesscowboy
2
Nor California
Welcome to TFP.
yes thought that would probably be the answer the u braces have the restraining strap that inter woven with the liner straps guessing if just run braces thru liner straps eliminate restraining straps be to high also
