resilience chlorine generator Model: 305PX
tpm
151
Hello all
a couple of days ago after vacuuming the pool I noticed my Hayward heat pump along with my Resilience chlorine generator Model: 305PX has stopped working. Heat pump has LP error which may be water flow issue. The salt generator has a blank screen ( direct wired to outside circuit panel and panel has power ). None of the controls work. Power, mode, etc. would this have a fuse somewhere to check? I turned off main pool breaker in house for several hours, i backwashed the pool but no help. After vacuuming the pool there was a lot of air in system that I purge.
any ideas?
Thank you
ajw22
23,517
Northern NJ
Pentair Intellichlor IC-60
I believe this is your SWG manual - http://edc.poolsupplyworld.com/wpdf/nexa_pure-installation_manual.pdf
Do you have a multimeter to check the voltage at the power connection shown on page 9 or 10?
Is your SWG wired through a timer?
What model filter do you have? When was the last time you backwashed or cleaned your filter?
Tom, please creating your signature with details of your pool and equipment.
tpm
151
Hello
Yes it is wired with a timer, goes on when pump goes on. I also have a Hayward DE filter that was NOT in need of a backwash but I did do one after this problem. Didn’t help. And really not good with using a multimeter although I do have one
ajw22
23,517
Northern NJ
Checking power through the timer with the multimeter is the next step.
What timer do you have?
Post pics of your equipment, timer, and SWG.
tpm
151
Will do that today. My Hayward heat pump went out along with it. Not sure how connected to the salt generator other than possible low water flow
tpm
151
34,000 gallon L shape with water feature on separate pump
Pump. hayward sp2610x15. 1.5 hp
Hayward DE filter. DE 6020
Hayward HeatPro heat pump
HP21404T140,000 btu
Resilience Salt Generator.
Dirk
8,624
Central California
Pentair Intellichlor IC-40
Excellent! Thanks Tom. Uh, I just realized we're calling you Tom. Did you actually tell us your name!?! ;) Maybe Allen knows you from your other posts. Good luck with the troubleshooting...
Beautiful pool and yard, by the way!!
Reactions: tpm
tpm
151
Thanks, Lol. Yes Tom is good ( although I’ve been called much worse )
ajw22
23,517
Northern NJ
You are back to tracing the power through the timer to the SWG with your mutimeter or getting someone who can do that.
tpm
151
I’ll need to find someone to do it unfortunately. It’s only 2-3 years old, same as the heater
tpm
151
So I found I definitely have power going to the salt gen. I even disconnected the cell to see if an error would come up but nothing . Possibly the circuit board is bad?
ajw22
23,517
Northern NJ
How old is the SWG?
What does a new board cost versus a new SWG unit?
ajw22
23,517
Northern NJ
Replace it with a new unit. Hayward Aquarite or Circupool.
ajw22
23,517
Northern NJ
Open up the SWG and post pics of what the boards look like.
tpm
151
I was able to grab some pictures before leaving
green circuit board with ribbon is for display
