Replastering a gunite pool
Jul 27, 2017
10
Lakeland, FL
Not sure if this is the correct subforum .....
Pool built in 2005, we moved in 2017. Have 4 small chips/divots in our plaster roughly 1/8-1/4" diameter where you can see the gunite
underneath. Otherwise the outer plaster is in good shape.
I read that gunite is not watertight and have noticed that water loss has increased very slightly over our normal evaporation (live in Florida)
Given that overall the plaster is in good shape, if no other chips occur is there an urgent need to replaster?
Hoping to put it off for 1-2 years if possible.
Thanks in advance
We were just in Lakeland this week. We like that town a lot!
Those small chips should have virtually no affect on your water level. How much are you losing?
In Florida, in excess of 1/4" daily is time to look for a leak. Are you losing that much?
The need to replaster the entire pool is not urgent but the exposed Shotcrete needs to be corrected.
The Shotcrete will absorb water and if the rebar inside is exposed to the water it will start to rust and may make its way to the surface as a stain but more importantly it will over time weaken the rebar and thus weaken the integrity of the shell.
Been in Lakeland 5 years now and love it. Growing a little too fast, infrastructure needs a boost to help support the population growth.
Water loss is roughly that 1/4" a day. maybe a tiny bit more. Our pool is open air, no cage and gets direct sunlight virtually all day. We did have a leak at the skimmer about a year ago that I patched.
Think to be safe I'll leak test skimmer, returns etc this weekend
Thanks
Thanks, did not realize that. I will get the chips patched/filled.
