Replacing Pool Heater
Jul 5, 2017
16
houston/tx
#1
I currently have a older 400k btu Jandy that does not work anymore. We are going to replace it with a new 400k btu. Any recommendations? I don't want the cheapest or the best. Something that will last but not hurt my wallet.
setsailsoon
604
Stuart/FL
#4
Here's what I have to offer:
  • I have a Jandy Jxi and I'm happy with it.
  • It seems to me the most recommended heater is a Raypack.
  • If you're doing the replace yourself though Jandy will not warranty it unless you do not buy online and you have a dealer warranty it. If you're using a dealer this wouldn't matter.
  • If you use iAqualink you may lose some of your features with a different brand or at least it may be more complicated to set up.
I hope this helps.
Chris
sktn77a
794
Chapel Hill, NC
#5
I've been very happy with Teledyne/Laars/Jandy gas heaters. First one lasted 15 years and only died because of an early freeze before I had winterized it. Second one is going on 9 years old with no sign of issues. I think if you take care of them and are careful with chlorine/chemical exposure, they can easily last 15-20 years.
borjis
2,643
Pacific NW
#6
I agree. The Laars Lite2 I had (was already installed when I bought the house) worked way beyond it's intended lifespan.
The membrane power switch had worn down though and was starting to fail, then I too lost the heat exchanger by not
draining it prior to a "once every 10 years severe deep freeze winter blast." But I decided to replace it with a Raypak based
on recommendations here.
