Replacing liner
T1DSoldier
7
21740
hello all,
I am replacing my vinyl liner and the bottom of the pool is concrete not vermiculite. I know this because it's rained and it is holding water. I have read it's fine and good contractors use concrete instead of vermiculite. Regardless the liner I just pulled out was wrinkled like a brain from shallow end to deep end. The liner was also pulled out of track in a few places. Other than that no water lose for a year.
My concern is rain water could slowly get under the liner from the sidewalls and not be able to drain and cause wrinkles.
Is this a legitimate concerns? If it is should I drill some relief holes and fill with sand or vermiculite?
Thanks in advance
Dave
jimmythegreek
In The Industry
Aug 10, 2017
2,450
Morris Cnty NJ
That looks like vermiculite to me. It's not soft when ita been there a while it feels like concrete. Dont drill holes in it and DONT leave that pool like that. Clean the bottom and get that liner in asap. If you have ground water it's not gonna matter now you have to deal with it outside of the pool. Steel wall pools need water to hold the walls up that's what pushes against the earth. Clean that algae too it will eventually show through liner when it turns black
kimkats
45,485
Tallahassee, FL
I am betting it was a poor install followed by poor chemical balance in the pool before you every got it.
Here is a set to links to help you care for your new liner when you get it:
Print these out:
Bookmark these:
Trouble Free Pool
TFPC is based on having your own test kit. Here is a link to show you the different ones we endorse:
Test Kits Compared - Trouble Free Pool I will tell you the TF-100 has more of the regents we use the most often. The Taylor 2006C is the next best as for as amount of regents.
Kim:kim:
T1DSoldier
7
21740
The liner is going in this week. Luckly I don't have a ground water issue. I thought the point of Vermiculite was to have a hard surface but allow drainage? Yeah I still have a little work till the liner goes in. I found paperwork that the liner was replaced in 2001 and there was vermiculite work done but I think it was just done at the base of the wall. The pool contractor said some spots feel like vermiculite and some feel like concrete "can't scratch it". I just want to make sure that's it's done right
T1DSoldier
7
21740
In the photo is a minimum of 4 to 1; cement / v16.
It’s a cement rich v16 mix, it was mixed on site; not bag mix.
I'm assuming thats ok? I found paperwork that the liner was replaced in 2001 and there was vermiculite work done at that time but I think it was just done at the base of the wall. The pool contractor said some spots feel like vermiculite and some feel like concrete "can't scratch it".
T1DSoldier
7
21740
Print these out:
Bookmark these:
Trouble Free Pool
Kim:kim:
I did buy k-2006 kit is that ok? House was empty for two years and the mail lady said even when people did live here new saw anyone in the pool. The surrounding area was very over grown so I am hoping the liner condition was due to lack of maintenance but I just wanted to be sure. My old neighbor in Jersey loves this site.
T1DSoldier
7
21740
I have not tested water coming. It is from a city source. My well has more iron then I want to deal with. Turned all my white fittings brown. Made some vitamin c spray and whitened it back to normal though.
DorsalSpine
488
Columbus, Ohio
You need to check your kit and see if you have a FAS-DPD test. I think I have to purchase one alone with my Taylor test kit. That's been a long time ago so it may have changed since then. Instead of matching colors you do a drop test to measure the chlorine level. It is much more accurate. Try tftestkits.net for the kit.
