Hello, I was able to remove the existing anchors with a core drill and purchased the schedule 80 anchors for replacement. My brother-in-law is an electrician so he helped bond the anchors so I’m ready to place both ladders (deep end and shallow entry ladders). I want to make sure I use the correct material to fill the holes between the 3” holes and anchors once they are placed in correctly.
Should I use cement or some other material? I went to Home Depot and one of the assistants recommended a self leveling concrete polyurethane the comes in the large caulk tubes. I wanted to make sure before installing.
Thanks!
Thanks!
