Replacement Light for Paragon Fixture Housing (Niche)
bedelk
3
Yardley, PA
All,
I've posted before that I have 2 Paragon lights in my In-ground pool. Both of them are toast at this point and i'm looking for a replacement. I've found new old stock for $1,400 a piece, but i don't need to spend $2,800 on pool lights. That said, I was rooting around measuring the niche the other day and found the original tag for the niche. It reads as follows:
Fixture Housing
(Pre-formed Niche)
Catalog no B-5601
It measures 10 inches at the opening and 9.5 inches from the rim to the back. Any suggestions on a replacement light?
MyAZPool
1,074
Arizona
Hi bedelk
There may be two possibilities (maybe). Just throwing out two companies that I am aware of that make replacement LED pool lighting products.
I'm not sure they can help you but give them a ring and supply them with your Paragon information and see what they have to say.
Good luck and let us know what happens.
Thanks..
r..
