Replacement for Spa controls??
Pat60
78
PA
We have a 25 yr old plaster pool with attached spa. The spa has an in ground ( attached pic) control that could filter spa , turn on heat, turn on blowers. Turning on and off blower was ideal . There is also a panel in the house that could do the same. Neither has worked for about 8 yrs. options at that time were to update panel at pool equipment, without a gaurantee that controllers would work. Any idea what the options are now and costs? Thanks!
Jimrahbe
15,063
Bedford, TX
Looks like a Jandy spa side remote... Spa side remotes are known for going bad as their inside gets corroded...
Does the automation system work other than the spa side controller?
Pat60
78
PA
The “Anthony 20/20 “ at the time worked for spa lights , pool lights, but nothing else. Nothing works now.( spa and heater). It was nice in the cooler weather to turn on the spa/ heater from inside. Now we don’t use Spa very much, But when we do would be nice to control the blowers without getting out of the spa!
