Hi, I'm hoping to find some help with a Sta-Rite System 3 S7M120 that was already installed when I bought my home.
I came across this thread that the S7M120 is identical to the S7M400, except for a difference in cartridges:
From info I found online, the difference between the systems is:
Does anyone know if I can simply purchase the filter cartridges for S7M400 and install them into my S7M120? From online pricing, the cost for the filters are similar.
And speaking of online pricing, any recommendations for where to purchase filter cartridges? It seems like OEM is the way to go...but it's hard to tell on some listings if they are OEM.
Sta-Rite Cartridge Filter - Do I have S7M120 or S7M400?
I always thought I had the S7M120 300 square foot filter, and that is what the "main" label on the upper tank says, but upon closer inspection there is also a sticker that says S7M400, which is 400 square feet. I assume the sticker has the correct information, and this is just the easiest way...
www.troublefreepool.com
- S7M120 provides 300 square feet of filter area and has a 100 gallon per minute flow rate
- S7M400 provides 400 square feet of filter area and has a 115 gallon per minute flow rate
