I have a Pentair clean and clear filter that has developed a crack in the bottom piece. My options are to replace just the cracked bottom piece for ~$300, replace the entire unit for ~$1000 or replace it entirely with a sand filter using glass media. If I went with the sand filter option they would add extra pipe and valves so I could add solar later on. Price for this option is ~$2000. It would be ~$1750 without the extra pipe and valves. Oh and I currently have a gas heater they would remove to make room for the sand filter. It’s too expensive to use the gas heater so why keep it. That’s included in the ~$2000.
So what should I do?
I’m leaning toward the cheapest option for now but thinking of putting a sand filter in the budget for the future. I need to investigate solar more before I do that to see if that’s feasible. While it would be nice to be able to swim earlier and later in the season I have no idea how much adding that would cost.
The top of the filter is deteriorating so the pool guy suggested painting it if I didn’t replace it too.
So my questions beside what should I do are what are the odds of the top part developing a crack? Should I go ahead and replace the whole thing to be on the safe side?
Is the glass media a good idea? Or is the cartridge filter still the best way to go
Do you think the extra water for backwashing would be about the same as buying new cartridges every couple of years?
Looking forward to hearing what you all think about my options.
Forgot to add that the pool was built in the late 1990s and it’s probably the original filter.
