Long time no see (mainly because my pool is very trouble free thanks to this forum). My Aquapure 1400 is throwing a code 121. This cell was installed August of 2020. The first cell was installed July of 2018. The first cell that failed was replaced under the 3 year warranty. I assumed this one would be as well since it had been less than 2 years, however the pool installer said that on warrantied cells like that one, they only give a 1 year so I would have to pay to replace it. Quoted $1450 plus a service call of $150 to do so after they tried replacing the cord (which obviously did not work). My question is since the pool is ~30,000 gallons, the aquapure is only rated for 40K gallons, I live in Texas and the pool is in the sun nearly all day making that unit barely big enough (during the worst of summer its running like 22 hours a day), can I replace the cell with a IC60? I have the iAqualink system, I have no issues if the salt cell isn't controlled via the web, just need to make sure the unions/fitting are essentially the same and that the salt cell wouldn't run when the pump was.
