So we had our friends’ girls in the pool today and somehow the plastic grille over the main drain has got broken up - sort of shattered - Heaven knows what they were doing in there! - with one large piece having dropped into the hole underneath and so far one small piece turning up in the pump basket. I also noticed thst the black gasket underneath the grille seems to be breaking down into black gunk. The whole thing is very old, c. 1980s. It’s a Certikin HD33.
I’ve ordered a replacement cover grille and gasket, but I had a couple of questions I hoped you good people might help me with!
First, how would you go about replacing a drain grille, I mean do I need to drain down the pool completely (draining and refilling completely will take days and c. 13,000 gallons)? or would you just drain partway and then grab some goggles and a screwdriver and duck underwater to fix it?
Second, if there are other small broken bits still in the pipe, how would you check/get them out/dislodge them? How can I stop other bits being sucked down when I drain the pool?
Thanks for your help, really appreciate it!
