Removing eyeball housing
igneous
94
DFW, TX
Testing the premise, I hooked up my sump pump with a 5’ piece of pvc with holes drilled in it for a redneck pool cooler and it actually worked...from 88 down to 85 overnite. Now want to rig a couple in the returns to use VSP power instead of separate pump, but can’t get the eyeball housings out. Does it take a special tool? Any self-engineered alternative tool someone’s used to remove these?
