Removing cement from water?
tomfrh
387
Australia
I've repaired some defective concrete in our pool and ended up with cement in the water. It's too small to filter properly. What's the best way to deal with it? Let it settle and then vac to waste?
Flocculants?
ajw22
5,973
Northern NJ
Here is a thread about concrete dust in pool water - Wondering about toxic effects of cement dust in pool
One point made there is concrete is very alkaline so keep an eye on your pH.
I don’t think floc is the answer. Turn off the pump and let the dust settle to the bottom. Then use your pool cleaner to suck it up. It may take a few cycles to get it all.
Bama Rambler
23,210
If all else fails you can get a 1 micron filter bag from somewhere like Duda Diesel and hook it to a return then manually vacuum the dust up and let it pump it into the bag to catch it. You'll have to block off the other returns if you have more than one.
tomfrh
387
Australia
Thanks! I wasn't aware of these.
Other Threads of Interest
