Hi. We just set up pool and I noticed displaced O ring at valve T. How do I disconnect hoses without water pouring everywhere? ( Intex prism photos attached)
How do I fix an o ring issue while hose is plugged in full pool? ( I don’t have valve). This is where hose connects. Do I have to pull this off and plug it to work on it’s below t joint?p
Stick something inside. A rubber plug, a carrot, a chunk of potato. Whatever. If you've got a grate over it, have someone hold a plastic bowl over it on the inside.
Welcome! You'll probably have to block flow from the inside of the pool at the ports. If you don't have a rubber expandable or winterizing plug, find something else that you can gentle jam into the port at the wall.
Thanks. I was way confused because I had forgotten the set screws in the “ screw on” strainer. Once I remembered the set screws, I could obviously simply remove the strainer and plug it. Thanks!
