Refill the pool before closing?
RynLikes2Swim
5
Cincinnati, Ohio
Closing our IG pool today. Leslie’s website says to “Refill the pool to between 4-6 inches below the skimmer inlet in vinyl liner pools and gunite or plaster pools” after we’ve add antifreeze to the plumbing. Is this necessary? What do you think of my water level here? Do we need a skimmer plug?
Thanks!
V___25
237
Central PA
I'd leave it. We have a Gizmo that goes in the skimmer so I'm partial to that.
Pool_Medic
In The Industry
Apr 1, 2018
1,554
Bangor Maine
IMO unless you get big rain/snow late fall, it’s too low. 1” below the returns is where most companies lower the water before blowing out lines. Companies use skimmer plugs and ultra gizmos and duck plugs without lowering the water, for one reason, speed of the closing. Both ways accomplish the same winterizatiin.
anthonypool89
958
Berks County, PA
I'm confused as to the advice. So you lowered the water level below the return lines to blow them out? And then are going to bring the water level back up after plugging the returns and adding antifreeze? Why not just leave the water level low. Unless you have a solid cover it'll fill up again anyway. I pump water off my pool to try and keep it below the skimmer all winter long (until / unless it freezes).
