A good friend of mine called me and is struggling with his pool....first question was type of chlorine and the answer was tabs. I ran my Taylor kit over and checked all his numbers. He is pretty out of whack. Here are the numbers for his ~17k gal pool:
pH = 7.9
FC = 5
TA = 150
CH = 360
CYA = 100
Temp = ~90F
LSI = ~0.8
He told me he had a bit of algae yesterday and so he shocked. I am not sure what his FC got to, but I doubt it was high enough to work. My thoughts are this:
1. Pump pool level down by 1/3ish to reduce CYA (and CH) w/goal to end up at 50. Alternative would be to toss hose in and let it run for a few days instead of renting a pump.
2. Get pH and TA under control.
3. SLAM with liquid chlorine
4. Clean filter and vacuum pool
5. Set him up to quit using tabs and switch to liquid
Would this be the best course of action?
pH = 7.9
FC = 5
TA = 150
CH = 360
CYA = 100
Temp = ~90F
LSI = ~0.8
