Hello, For the past two years I have been a pool owner here in Phoenix, with 10,000 gallons in ground pool, with constant algae problems.
I have never been able to get the test strips to read good despite using much chlorine tabs and muriatic acid. Also algicides.
I read that I need to use more Muratic Acid because of the very high water supply hardness. Also we get a lot of dust storms and leaves. Would that make hardness worse?
So yesterday I added two gallons of Muriatic Acid and 5 chlorine tabs. The algae is better but the pH look too far the other way now.
What chemicals should I be adding to my pool in the summer? Also what is the cheapest source of chlorine these days it is costing alot! eg liquid or shock or tabs etc
Thanks in advance.
Thanks in advance.
