Re-Plumbing the Pool Equipment Pad
MyAZPool
1,816
Arizona
Pentair Intellichlor IC-60
So, finally completed. Whew, that was quite the project all in all. I sure appreciate all of the help that I received from everyone. The photos above posted earlier in this thread, was the initial plumbing and electrical completion back in September , but I had yet to integrate the IntelliCenter automation, IntelliValves, IntellipH and a few other minor additions to the overall system.
Anyway, here is my completed "project" photos (don't hate me too much Jim, you were the one who gave me a some of these ideas :p )
Load Center with IntelliCenter Install
Plumbing and Electrical
Low Voltage and Line Voltage Junction Boxes, Water Meter Enclosure and IntellipH Controller
Temperature Probe wrapped in Foam Insulation
CMorrow
48
Austin, TX
Just reading your thread today. I am still green when it comes to a project like yours, but I must say it's clear you put a lot of thought into it, and it looks great. Congrats on tackling and completing a big job like that.
Reactions: MyAZPool
MyAZPool
1,816
Arizona
CM
Thanks very much. There were times that I thought that "I had bit off more than I could chew", but I got through it, with the help of others here.
I must say though, that I am a bit jealous that you are using a Dolphin Robot :p. Nice!
darinclifton
Active member
Jun 2, 2019
34
St. Louis
Can you explain what is happening with your temperature probe and how you installed it? Do you have a picture without the insulation? What did you jacket the wire with?
MyAZPool
1,816
Arizona
All
darinclifton
1. All of my wiring on my pad is protected with high temp split "wire loom". It's readily available at many outlets. Check out Amazon, Home Depot, Lowes, etc.
2. Here is a picture of my temperature sensor without the protective insulation. I used a standard 1/2" electrical strain relief compression fitting.
darinclifton
Active member
Jun 2, 2019
34
St. Louis
All
darinclifton
Thanks so much for the reply, I see you have a ~2" T - what is the strain relief threaded into? I am surprised that you were able to get it to seal under pressure, how did you accomplish that task? I am assuming that you are getting good numbers. I am looking to do something better than the compression collar, they look like Rear. Your install looks very nice!
darinclifton
Active member
Jun 2, 2019
34
St. Louis
I'm thinking this is brilliant. After looking again, it appears that you are using a spigot plug? I didn't realize that a strain relief plug could take pressure, a quick web search show ratings of 5 bar! please confirm that this was your approach and any difficulties that you might have run into . Thanks again for sharing your build!
MyAZPool
1,816
Arizona
darinclifton
Correct 2"x2"x2" tee. 2" slip to 1/2" treaded adapter. Pretty sure it's a strain relief adapter but maybe it's called something else. I didn't think of the idea, I used info found here on TFP in other threads. You can try searching around on TFP for the proper name. Just not 100% sure now because it was a while ago.
I'm pretty sure that this is it.
Yea it's a good idea but I didn't think of it. I just followed guidance found here on TFP. No difficulties with this at all.
Thanks...
r.
dianedebuda
438
Austin TX
I'm pretty sure that this is it. [Morris Products Nylon Cable Glands]
Had trouble with the Morris gland - acted like it was cross-threaded when close to tightening. Fortunately had some others, so used one of those. Even when tightened as much as I could, didn't seem like it would take much pressure to pop the probe. Currently have some velcro instead of a screw band to hold it in place. Did you need to add anything to prevent pop or were you able to get the gland tight enough? Afraid of tightening too much and damaging probe.
Dirk
8,624
Central California
Pentair Intellichlor IC-40
I had originally thought a 2" x 3/4" x 2" tee was a cleaner install (I needed a hose bib for draining solar for winter), but a pool plumber corrected me, siting that was a good way to snap off my PVC if the bib got tripped on. So apparently 2" x 2" x 2" with a reducer is the better way.
I wrap all my wire and tubing stuff with the split loom, too, from Lowes. What does "high temp" mean? I think mine is "UV," but I figure I'll still need to replace it periodically. Better to replace that stuff than the much more expensive stuff I've got it protecting. Is there something tougher than the UV stuff I'm using?
Reactions: MyAZPool
MyAZPool
1,816
Arizona
dianedebuda
I also agree with all points made by @Dirk above.
Much better to use 2"s x 2"s x 2"s tee's and then use either a 2"s x 1/2" Reducer Bushing Spigot x FPT (threaded) or a 2"s x 3/4" Reducer Bushing Spigot x FPT (threaded), depending on the application, for any acid injection, water temp, pH and/or FC sensors, IntelliChem Flow Cell Inlet/Outlet, etc., plumbing taps.
Like this.
You will also find a very large selection (size and colors) of split loom on Amazon....
When using the morris glands, I've had no problems with leaking but I might have used just the right amount of teflon tape (not too much and not too little). 3-5 wraps should be about all you need. Take your time with the wraps (no dimples), and insure the tape is smoothed out and gets into all of the threads nicely with your finger before installing the male threads into the tap. Gently thread and don't over-tighten too much.
r.
dianedebuda
438
Austin TX
Thanks @Dirk and @MyAZPool, but I'm not asking about the tee & reducer nor threading the gland into them. Have already done that. It's the smooth probe inserted into the gland and tightening that I'm having concerns about.
MyAZPool
1,816
Arizona
Oh, gotcha. Yea, I have not had any problems with that. Just keep working with it. Mine works fine. No leaks at all.
Maybe the one you got is defective somehow.
r.
dianedebuda
438
Austin TX
Haven't tried it without the velcro strap, so maybe isn't a problem. Sure doesn't seem to take much to slide the probe out though. Just spooked I guess.
Dirk
8,624
Central California
Wish I could help. Sorry, no experience with that probe. ( I was actually posting to MyAZPool.)
Reactions: MyAZPool
MyAZPool
1,816
Arizona
You should be okay. Just work with it and take your time and it will be good. Like I said, over two years and zero problems with it coming loose, leaking or anything like that. (y)
Turbo1Ton
500
NE Oklahoma
What is the thought process on the 2x2x2 tee with bushing, vs a 2x2x1/2 tee? I understand for Dirk's situation where you are installing a hose bib which is metal and stronger than the surrounding materials, but for the temp probes and injection points, I would think that the 1/2" branch would be fine. Getting ready to FINALLY install my IntellipH and I will be adding several of these 'taps' so that I have locations for 'future' sensors, if necessary.
--Jeff
Dirk
8,624
Central California
Well, if you're forcing me to fess up, I did the bibs correctly, but I didn't follow my own advice for the IpH probe, because it's all plastic so I figured that would snap before the tee did. Do as I say, not as I do!! ;) It was a moment of weakness! If I were to do it again, I'd use the 2x2x2.
Turbo1Ton
500
NE Oklahoma
I think for the sensors and stuff like that, I prefer the ones with the 1/2" or 3/4" branch connections, as the temp probes might actually get into the flowing water instead of the weird quasi-stagnant pocket that is created from the larger 2" socket. But I'm weird like that. I definitely understand that from a strength perspective, the 2" branch will be able to withstand more side loading, especially with the bushing installed.
--Jeff
