Raypak RP2100 "fireman switch" open, where is it, what is it
rock
263
#1
My Raypack RP2100 pool heater doesn't turn on.
The error is Fireman Switch open.
There's no part called a fireman switch in the exploded diagram.
http://www.poolcenter.com/parts_heaters ... al_pg2.htm
What's/Where's a fireman switch?
There is definitely propane gas in the line (the BBQ further down works fine).
I don't see any place to light it up.
Any suggestions?
JasonLion
Platinum Supporter
#2
Re: Raypak RP2100 "fireman switch" open, where is it, what i
The fireman switch is external to the heater, usually used by a timer or an automation system to control the heater remotely.
ps0303
In The Industry
Jul 6, 2011
3,954
FL
#3
Look inside your timer box. That is the usual place to put them.
rock
263
#4
Thanks guys for the help. If it's external to the heater, that's probably why I can't find it on the heater (there's a thermal fuse but that's it).
So, I'm still looking for the fireman switch.
I'll snap pictures in the morning.
Does anyone have a picture of what the fireman switch looks like?
JasonLion
Platinum Supporter
#6
Follow the low voltage control wire coming off the heater and see where it goes. While you are doing that, check the wire for cuts.
rock
263
#7
That is a great idea! I see a single white wire tie wrapped to the outside of the electrical conduit. Following that wire, it goes eventually into the control panel for the pool. From there I'm not sure since it's in the back of the panel.
I'll see if I can snap some pictures as there are other things I don't recognize around that wire so it may be a different wire.
Thanks for the kind help - I know you don't have to help any of us ... and I double appreciate it that you do. It's my job to get you some more information which I'll try to do soon (I'm at work right now so can't do it).
Pool Clown
In The Industry
Sep 5, 2008
1,813
Silicon Valley, CA
#8
Are you trying to turn on the heater at the heater? Or are you doing it from the compool in the house, and came out to the heater when you weren't getting any heat?
Kias
662
NW Ohio
#9
Why is it called a fireman switch?
Obviously not a switch for the fireman, if it's not easily found, like in an elevator.
Sent from my Galaxy Nexus
