Raypak 8450 can't access any menus
nobueno
76
Erie, CO
We just finished hooking up our Raypak 8450 heat pump and can't access any of the installer/service menus or any other menus for that matter. The electrician hit the jumper and it turned on so it has the appropriate power. The menu just displays the 'time' 'water temp' and 'off'. No errors. None of the button combinations in the manual are working to access the user or service menus though. Tried cutting power and restoring but no dice.
I'm almost starting to wonder if we got a used unit. The tip 'n tell was good so it didn't fall over and there were no dents/holes in the box but once I unboxed it there's a huge dent in it. This coupled with the fact that it's supposed to default to the installer/service menu on initial startup are starting to make me wonder...Thoughts?
nobueno
76
Erie, CO
I got it figured out. Ribbon cable on the back of the board was disconnected. Few pins bent but straightened them out and we're good.
