Raypak 336A and Pentair Intellicenter
Paresh
7
GA
New member here seeking help. Can anyone tell me how to connect the Raypak 336A to Intellicenter for automation on my pool/spa combo.
We have followed the instructions and cannot get it to work with the automation.
We have tried both the firemans switch and 7 pin connection. No matter what the heater powers on and we cannot control it from the Intellicenter.
Can someone send me instructions and any information that could help?
Thanks in advance
ajw22
24,658
Northern NJ
Pentair Intellichlor IC-60
You need to control the heater with the 2 wire firemans switch.
Post pics of the connections at the heater and IntelliCenter.
Chances are you have a setup problem in the IntelliCenter.
Do you have the filter/pump on when you call for heat?
You check that your heater works in standalone mode?
Please create your signature with detaislsof your pool and equipments so we have a complete view of what you have.
Paresh
7
GA
My installer did try with fireman switch
Here is a pic of connection at Intellicenter (disconnected for now)
Pic of connection at heat, with firman's switch connected
Fireman switch disconnected
Yes, filter/pump is on when calling for heat?
