Raypak 266,000 btu natural gas heater Error messages "sensor failed" and sensor shorted"
Jim GOZZ
4
Chicago
Last year I believe gas built up inside the unit and when it finally lit, the door blew off.
that being said, it ran fine after that but later in the year I started getting the error messages "sensor failed" and sensor shorted" and the display tells me "No Demand and temp 213degrees.
what can you tell me?
Welcome to TFP.
You need to replace the temperature sensor thermistor. Page 46 in http://cdn.globalimageserver.com/FetchDocument.aspx?ID=c404f1c5-ac50-4209-9457-56246d010b20
Part 6C. P/N 009577F
Welcome to TFP.
That's very helpful...I'm guessing that is on the right side of the unit and hopefully not too hard to change out. Thanks for all your help, I'll let you know if I'm able to get it going.
Check for other wires the mice chewed on.
