Rattliing in multiport valve
kywildcats
620
Mayfield, KY
#1
After recent pump replacement, I have a rattling in the multiport valve when pump is on high. Can I just take the screws out of the top of in and lift it off? My bet would be a small piece of PVC that could have dropped in pump while replacing. Any guidance would be appreciated. Thanks!
Texas Splash
Hey Mark! :wave: Sorry for the delay. I figured a ton of people would've already replied to you on this one. Yes, you can remove the screws on top of the multiport valve to inspect inside. Just make sure to place the top back onto the housing in the same orientation when you're done. Hope your fix is an easy one.
