Raising PH without causing cloudiness
firstpool2020
12
Kentucky
If you have read my post history, you know it has been a ride! Pool is now not cloudy, free of flocc, free of algae, nice and clean but the PH is off. Last shocked about 24 hrs ago. Readings are as follows:
FC - 5
PH - 7.0 or less
TC - 3
Before we shocked it we were at:
FC - 3
PH - 7.1 about
TC - 3
I cannot do FAS-DPS due to lack of testing kit and cannot get one quickly, I have to work with what I have. Testing kit says add soda ash but will this make my pool cloudy? I read the guide and also another post on here from someone who used the calculator added 5.5lbs of it to a 6.9 PH pool and it shot up to a PH of 11 and was cloudy. So now I am scared.
Help?!
RETESTED SINCE POSTING:
PH - Less than 7
Drops of Base Added to get it to 7.4 = 8
FC - 3
TC 3
CC - 0
TA - 50 PPM
mknauss
35,937
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
mknauss
35,937
Laughlin, NV
Fiberglass
Also, your TC cannot be less than FC.
markayash
2,878
Atlanta Ga
Ph Up can make the water cloudy if you add too much too fast. I learned the hard way and wish I had done it in steps
Richard320
23,932
San Dimas, CA (LA County)
FC - 5
PH - 7.0 or less
TC - 3
FC - 3
PH - 7.1 about
TC - 3
Help?!
You either need a TA reading for poolmath or a base demand test result to do some number crunching to know the dose. Even if the water clouds up a little, it won't last long.
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
34,517
Use 20 Mule Team Borax to raise pH. It will not cloud your pool. Assume your pool is 6.8 pH. Calculate and add enough Borax to get your pool to 7.4. Test in an hour or so and adjust if necessary.
Reactions: markayash
firstpool2020
12
Kentucky
Is there a benefit to Borox over soda ash? Also, should I add the full amount at once or do a bit at a time as I test.
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
34,517
Assume 6.8 and calculate the dose to 7.4.......all at once. You will not overshoot if your math and dosing is correct.
