Rain turned pool orange !!!!
ttomp
20
Gonzales, LA
I just filled it the other day (well water) and when I added chlorine it turned orange so I added a metal sequestrant. That cleared it up so yesterday I shocked it with bleach and it was fine late yesterday evening. We got a big rain today and it turned it orange again. Does rain have metals in it or do I have something else going on? What do I do now?
Cl2 10ppm
pH 7.4
TA 110
CYA 20 (stabilizer dissolving now in pool)
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
31,709
Add more sequestrant. The rain apparently changed the pH just enough to allow the metal to precipitate.....very unusual....How much rain did you have?
ttomp
20
Gonzales, LA
Just by guessing I would say 2-3 inches between last night and today. Raised my pool level about 4 inches til it was overflowing through the skimmer.
Bama Rambler
23,046
I think there was a couple things that happened here. One you added sequestrant a week ago. You then shocked the pool, THEN it rained. High chlorine levels will precipitate out iron and it has been long enough that you were close to needing a maintenence dose of sequestrant again, then the rain diluted the sequestrant dose a bit more and probably raised the pH as Dave said, and voila, it turned orange.
I wrote all that just to agree with Dave "Add more sequestrant"! us Daves got to stick together.
DWSPool
84
Southern Indiana
I think the idea of iron precipitating out after a pH change is sound, except for the fact that rainwater is slightly to moderately acidic; normally in the 5 to 6 range due to dissolved carbon dioxide (carbonic acid), but could be more acidic near urban areas due to air pollutants. I don't have any other bright ideas, but I thought I would throw a wrench into the works here - sorry :?
DWSPool
84
Southern Indiana
:idea: How about temperature change? Cooler temperature rainwater - decreases iron solubility, iron precipitates, orange water. Or, increase in oxygen level, leading to ferric iron (tri-valent) as opposed to ferrous iron, the more soluble form.
JohnT
Admin
9,475
SW Indiana
Rain always raises my pH. It may be mechanical and due to the aeration from the raindrops hitting the water in the pool, but inevitably I have to add acid after a heavy rain.
ttomp
20
Gonzales, LA
I did add sequestrant yesterday evening cause I didn't want to wait to long so I just did it. It looks better this morning but I still need some more. I didnt want to over do it. I just wanted to make sure that it was possible for the rain to cause this and not something else. Once again Thanks !!!!!
Other Threads of Interest
