I am looking at installing a Radiant Metric Series Above Ground pool. It will be semi in ground and will mainly be used to swim laps Also I have space constraints.
Two questions:
-Is there a minimum in ground depth? I’m building a deck so need it to be 1’ underground and 3’ above.
-Can you do custom sizes? I see the panels are 4’. Their Emerald comes in 12’ x 20’ - could we swap a panel and turn that into a 8’ x 24’?
Thank you!
Two questions:
Thank you!
