Hi!! This is our first year with our inground saltwater pool. The build was completed in mid-March. Our pool looks amazing. We take care of it ourselves and are happy we’ve done such a good job maintaining it throughout the spring and summer. We plan to keep it open all winter. I’m curious as to what maintenance is required throughout the winter? Is it pretty much just keep doing what we’ve been doing all spring/summer?
We have a variable speed pump and have been running it 24/7 at 2500 rpm since the pool has been completed. It doesn’t seem like it’s increased our electric bill too much, and it’s given us peace of mind that our pool is functioning well, chlorine levels are being maintained with our salt generator and skimming has been keeping everything clean. That being said, is it ok to continue running the pump 24/7 during the winter? And, if so, should we decrease the rpm to a lower level?
I realize the salt generator doesn’t function when the water temp gets below 55 degrees, and that we’ll need to turn it off and add our own chlorine to supplement at that point. From what I’ve been reading here, putting pucks in the skimmers are bad because they also contain CYA and will jack that level up too high. Do they make those pucks that do not contain cya, or should we just use liquid bleach? If bleach, what specific kind/concentration of bleach should we use?
I read somewhere in these forums that winter pH should be maintained a little higher, around 7.8-8.0? Is that correct? Just curious about the rationale for that?
Our pool and hot tub are attached, so I realize that when running the pump (circulating the pool), the water will still be overflowing the spa spillway, but is it ok to still run the bubblers throughout the winter, or should we turn those off to prevent aeration contributing to a higher pH (we’re currently always working to drive our pH back down).
Thank you in advance for any help/guidance you can give. TFP/pool math has been an amazingly helpful resource for us as we’re trying to navigate our way through our first year of inground pool ownership.
