Eric, not a problem
I think you're doing the correct thing in just replacing the sand (& I don't buy into the sand needs to be replaced every "X" years :!: )
You have possible filter issues and the parts to correct them, so why not change the sand while 'rehabbing' the filter?
I almost said something about sanitizer levels in my first post to you, but, instead concentrated on the mechanical issues (I also knew Dave would be along to discuss the clarity issues, as he is THE proponent here on 'cloudy water = no/ low chlorine' )
Your Triton filter should have a double drain plug. The smaller one will let water out, for draining, while keeping the sand in. The larger one will let the sand out (it's got ~ a lateral attached to it).
It's S-L-O-W to get the sand out that way and you have to keep shoveling the pile out of the way to keep the flow going - and keep a garden hose flowing into the tank to facilitate the emptying of the sand. I just use a shop-vac and suck the sand out - watch the weight of the container, wet sand is HEAVY!
If you have any questions about changing the sand, or replacing the laterals or the bulkhead fittings - all you need do is ask.
