So new equipment and plaster has been running since mid June. At the end of June, and at the end of the plaster care, they cleaned the filter. However, just after a short period of time, I’ve already had to open it up and clean it. This is the Quad 60 DE cartidge filter, without backwash. When I had this installed, the rep said I would only need to clean this a few times per year. I was a bit surprised, when my PSI already spiked after just a short period of time...
Is this normal due to the new plaster (just standard white)?
My pool doesn’t have a lot of direct leaves, but lots of small particles and dirt are always flying into the pool due to surrounding neighbors with huge trees....
Within the last couple weeks, I started using a sock filter on the skimmer and I brush and skim the pool religiously and run the Polaris daily, so their isn’t a lot of debri left in the pool.
After I cleaned it, it’s currently at 20 psi. Is that sounding about right?
Should I basically just expect to clean it WAY more often than the “couple times per year” that I was sold on?
