Question about stopping reverse water flow
SunshineStateofMind
2
Southwest Florida
I have a typical Florida pool/spa setup. In the spa I used to have a water feature which I didn’t care for. It causes uneven flow back into the pool. It was screwed into the floor of the spa via PVC. I removed it and at night when the pump stops, the spa level drops by half. Is there a type of fitting I can put in the 2” ground fitting on the spa floor which will open when there’s water flow and close when there isn’t? Thanks!
Andrew_D
161
Manitoba, Canada
Hayward Salt & Swim 3C
I've seen floor drain valves but they are more like a backflow prevention valve for a basement floor drain. Water goes down, not up. You want the opposite. There's likely one out there, so hopefully someone will chime in!
If not, a one way check valve at the equipment pad would be easy to do. (I say that without seeing your pad!)
Andrew
Chasarms
355
Dardenne Prairie, MO
it doesn’t matter where the check valve is on that line. It will prevent back flow. It probably makes more sense for it to be in the pad, if possible.
Just pay attention to the direction you install it and be 100% sure you understand the plumbing before you cut anything.
