Question about CYA ppm with SWG
May 10, 2018
6
Canton, GA
#1
I am curious about why the CYA needs to be 70-80 ppm with SWG. Isn't that very high? I keep mine around 40 ppm with free chlorine around 3 ppm and I haven't had any issues with the water.
jblizzle
41,197
#2
:wave: Welcome to TFP!!!
A SWG adds FC very slowly. A higher CYA will better protect the FC from the sun. At a higher CYA level, you may even be able to lower your SWG output (extending its life) and still maintain the higher required FC level.
The FC level you are maintaining is fine, likely just need to keep it above 2ppm for a CYA that low.
