PVC sizing confusion
september
2
Chicago, IL
I will have my pool installed in a few weeks. 12x24 Doughboy with a 1hp Hayward xstream cc10092stl pump/cartridge filter that has 1.5" input/output and a 150k btu Hayward h150fdn heater that has 2" input/output so I am a bit confused on what proper size PVC piping will be needed in this setup?
Pool will have 1 return/1 skimmer. Should they run 1.5" pvc pipes from pool to the pump/filter then 1.5" with a 2" adapter to the heater and then another adapter 2" to 1.5" back to the pool? Or 2" PVC everywhere with reducers for 1.5" where needed?
september
2
Chicago, IL
I will have my pool installed in a few weeks. semi inground 12'x24'x52" Doughboy with a 1hp Hayward xstream cc10092stl pump/cartridge filter that has 1.5" input/output and a 150k btu Hayward h150fdn heater that has 2" input/output so I am a bit confused on what proper size PVC piping will be needed in this setup?
ajw22
24,667
Northern NJ
Pentair Intellichlor IC-60
1.5" pipes and reducing to 2" at the heater will work fine.
Richard320
23,932
San Dimas, CA (LA County)
Calculating flows is beyond me. But look carefully at that pump and filter. Sometimes the fittings are dual-sized - ID fits 1.5", OD is the same as 2" so you can use a coupling on the outside. If so, you could use 2" throughout.
Let's see what @JamesW has to say
JamesW
23,912
I would do 2" everywhere and reduce as needed.
I would definitely not do a single speed pump.
I would go two speed or variable speed.
