I have a Pentair IntelliFlor VF variable speed pump and an in-ground, chlorinated pool. I'm running the pump on Filter Mode. The watts output of the pump, after priming, first rests at about 240 but increases at a rate of about 10 w per hour. Is this a sign of a problem elsewhere?
I don't know if it's relevant but: There are no bubbles coming out of the return lines in the pool, and filter pressure is at 5 PSI and doesn't change.
I thought the issue might be coming from the air relief valve on top of my cartridge filter (Clean and Clear Plus) and when I took the valve apart found the small o-ring damaged. I replaced the o-ring (with what seems like the appropriate fit--I couldn't find documentation on the size of the installed o-ring) but the issue with the watts creeping up continues.
Any ideas on why the watts increases over the hours the pump is on is appreciated! Thank you!
