New pool owner, pump hums and trips breaker on 1st start then hums and clicks inside pump before it starts and run fine turning on and off fine until it’s off for 8+ hours I would say. Replaced capacitor still doing same thing. Any thoughts thanks
Replace that whip first. It has got to be arcing judging from that last picture and you OP. Even if it is not arcing yet, which I bet it is, whips are only 17 bucks at lowes. That much electrical tape rapped around the ends of those wires is your first, and maybe only problem. Other than a future house fire lolwhat pump would you guys recommend for replacement, the pool is 18,000 gal with 1hp pump currently, thanks
