Pump surge question
Nordy-que
Active member
Apr 2, 2021
33
Florida
In the midst of a pool refinishing startup. Lots of things have changed since there are new drain covers, jets, etc. I’m getting air in the system periodically that I can generally solve by lubing the pump filter cover o-ring. Since I’ve been messing with it more over the last few days and playing with valve settings again, I noticed that if I turn off the skimmer completely, or even a little too far, I get a ton of air in the system and the pump will surge.
I’ve got a 3 way Jandy valve for the spa drain and jets, wondering if that would be the culprit, but don’t understand why I’m getting more air in if I only have the main drain inlet on and nothing else. Ideas appreciated!
Nordy-que
Active member
Apr 2, 2021
33
Florida
No air in system currently, but the question remains: if I turn off the skimmer, is it normal for the pump to surge?
Nordy-que
Active member
Apr 2, 2021
33
Florida
Thanks - I haven’t had a pool for long so still learning. I assumed, incorrectly I guess, that diverting all the water to one inlet would provide enough flow.
Pool_Medic
In The Industry
Apr 1, 2018
1,451
Bangor Maine
Are you certainly the main drain was fully primed? It sounds like it might not be, when I open pools up east. One line gets fully primed before we open a valve to then start priming another, the instant you move that valve the pump will lose prime and surge until themain drain is fully primed.
Nordy-que
Active member
Apr 2, 2021
33
Florida
I’m thinking now that I still have chunks of plaster and what the pool builder called cream in the drain line. I thought it had all broken loose but I had a basket full of the stuff again this morning.
Reactions: Pool_Medic
mas985
14,038
Pleasanton, CA
Is your pool water level high enough? It needs to be at least half way up the skimmer opening.
Nordy-que
Active member
Apr 2, 2021
33
Florida
Replaced the jandy valve o rings on both inlet and pressure side. Zero air in the lines or pump housing now!
