- Jan 2, 2018
- 563
- Fiberglass
- Pentair Intellichlor IC-60
Circulation was slow when in Filter mode, so time to clean the filter. Afterwards, pump remains in prime mode and finally does an auto shut down. Only things that I touched were cleaning strainer, turning the Jandy valve at filter drain and the filter. Strainer seal not a problem 'cause in Recirc, pump works as it should. Jandy valve seems to be shut 'cause don't see any water in drain pipe. So must be filter. Pressure valve shows expected pressure after a cleaning and no leaks noticed. Opened filter back up and again checked that gasket is in good shape, regooped it and cleaned track. Gasket seems to be positioned correctly and band on filter tightened to where spring coils touch. Same result on restart.
Now in Recirc mode and awaiting delivery of DE for another try.
Thoughts on what I might be overlooking?
