Hi,
I am taking a hard look at my electricity and from what I calculate, the pump is running my around $300 a year to run.
Cleaner: 2 hours a day @ 3450 RPM or 2440 Watts or 2.4 KWH for a total of 4.9 kwh per day.
Spa: .5hr a day @ 3450 RPM = 1.22 kwh per day
Pool: 9.5 hours @ 1500 RPM or 192 Watts = 1.8kwh per day
After you do the math, you get to a total kwH of ~250 kwH per month or $25 dollars a month or $300 a year.
Is this overkill? The big drain is the cleaner, 60% of my kwH usage. Does the cleaner need to run the pool at 3450? Could I lower the cleaner and raise the pool to compensate? Maybe from 1500 to 1750?
Just had a $300 electric bill so trying to ease the pain coming with this hot summer.
Thank you
Edit: I do have a Booster Pump so I am probably definitely wasting money by running the VSP that high.
Thank you
