not pool in signature
The pool in question is a gunite approximately 20k with attached spa. Equipment pad has NG heater, nature 2 SWCG, pressure side cleaner, and main filter pump which is Jandy Pro series, Model PHPM2.0 ,serial V16FA0148 and air blower motor for spa all controlled by a "AquaLink RS Pure Link" which is new territory for me. Pump motor is shot with high pitch bearing failure.
Question, I can replace with the same Jandy motor or get a VGREEN VS 2.7hp. Will the VGREEN work easily with this control to make it worth the while or will it need some extra electronics and wiring to make it work right. Any help here is appreciated,
Thanks in advance,
Allan
Thanks in advance,
Allan
