Pump ran dry for 1.5 hours - did I ruin it?
Poolweekender
40
Hudson Valley, New York
Hi - I closed my AGP yesterday and left the pump in place for removal today...but forgot to turn the timer off yesterday :brickwall:
So this morning the pump ran dry for 1.5 hrs and was still running when I unplugged.
Any idea if I’ve ruined the pump?
I’m thinking I can test it by pouring water in the basket...
P.S. It’s a HAYWARD MATRIX 1 hp pump.
Justin
Wistlo
5
New Orleans, La
Been there, done that with a Hayward Super II
The teflon slip ring and the impeller were damaged by overheating, but nothing else seemed affected. This happened several years ago and the pump has been running trouble free since.
wireform
In The Industry
Aug 15, 2017
1,484
Spring Valley, NY
Thanks all.
Wistro - I assume you replaced the impeller and ring? Is that difficult to do?
Justin
Wistlo is speaking of the mechanical seal aka shaft seal and Impeller which are relatively easy and cheap if you're a diy guy. I'm not sure what would go bad with the Impeller but if he said it went bad I guess he saw it.
Reactions: Wistlo
Wistlo
5
New Orleans, La
Sorry for the delay, just saw this.
As I recall (it's been awhile, 2013), the impeller was deformed, slightly warped by overheating. One don't want any deformations in spinning components as that will wreak havoc on bearings and seals (and make noise, too), and if the impeller disintegrates the failure could be catastrophic (destroying the housing, locking up the motor, etc.).
These were the two parts I replaced:
Hayward SPX3010C 1-Horsepower Impeller Replacement for Hayward Super Ii Pump
Hayward SPX3005R Impeller Ring Replacement for Hayward Super Ii Pump
Everything else on the pump is original (except the basket, that cracked and needed replacement at some point.) And the motor, too; those have lasted 2-5 years. Pump was there when I bought the property in 1997.
Somewhat off-topic: I'm currently debating whether to upgrade to a variable-speed pump, but I'm worried about durability especially for such a costly piece of hardware. My HVAC system had variable speed high efficiency motors when originally installed (2002). We get a lot of lightning here and those motors failed during storms more than once, and ultimately the manufacturer discontinued them. I now have one system with the variable speed motor and the other with the standard one-speed motor. I also had to replace a dishwasher control board that I suspect succumbed to a lightning-induced power surge. I wonder how an electronic variable speed pool pump motors stand up to our spectacular lightning.
