I had a Northstar sp4007 3/4hp and the prime was good until my DE pressure would get high and I would clean the filter and always had a full prime bowl. I replaced the pump with a Jaccuzi 185 which is a Hayward SP32900VSP in disguise. I can't get the bowl to fully prime, I checked the connections used lube and tape for the input and output. It goes to just above the basket. And idea's? I've tried just to drain, just to skimmer, just to vacuum line and a mix of all same results. DE Pressure was 10-20 with Northstar, now it is almost 20 in motor prime mode. drops below 10 when at 1750rpm or so.
